Check Engine Light AND ABS light ha.
Throwing up code PO401 EGR code. I've replaced the EGR valve, came on 25 miles after i put it on. [:@]I cleaned all the carbon out from underneath where the EGR valve sits, light came on two days later. Any ideas? Yes it has 183k on it and i don't really care for it being on because it drives perfectly okay. But good hell that light is annoying.
AND...
ABS light is on. I put it up on the lift at work, removed all the ABS sensors on all four wheels individually and cleaned them thinking that would do the trick and the light came back on..
Any ideas?
I'd really appreciate it. Thanks.
AND...
Any ideas?
You signature is working now. The ports are still the likely culprit.
Google t2t013.pdf
The last couple of pages show how to clean the EGR on a 5th gen (94-97) accord.
Google t2t013.pdf
as for the ABS, you should get the code(s) stored for the ABS. The DIY section has a thread called ACC 5th Gen....., dhost link has a shop manual that you can download with instructions at the bottom of the page split into chapters.
Also the CEL procedure linked on that page will be the same thing you will do for the ABS light, except that you count the ABS light flashing. Just use a thin paper clip to short that service connector.
The codes are different than the CEL and have two parts (like 1-2, 2-4, etc..) Post those codes.
93Accord2.2
Nov 7, 2013 07:10 AM
mickey4live
Jul 6, 2012 08:29 AM
78gaw
Jan 20, 2010 09:45 AM
PAY1920
Jul 1, 2007 09:58 PM
