Check Engine Light, but no codes
Old Feb 18, 2016 | 06:19 PM
AndysAccord's Avatar
Default Check Engine Light, but no codes
I have a 2004 Accord V6 that is in great running conditions. 129k, new timing belt, consistent oil changes, etc.
Recently the Maint Req'ed, Parking Brake, Check Engine and Traction Control lights came on.
I took the car to the local auto parts store to try to see if I cold pull any codes from the ECU to see if something was not functioning properly, but no codes were returned. Everything looked good.
Any ideas why all those lights/icons are lit up on my dash? I'm trying to avoid taking the car to the dealer to have them charge me $100 to turn off the lights
Old Feb 18, 2016 | 06:49 PM
Symptoms may be due to battery, battery connections, charging system, etc.
Old Feb 19, 2016 | 01:47 PM
Turtlehead's Avatar
Sounds simple but check the brake fluid in the reservoir. The computer system is somewhat complex in your car and if the parking brake light is on then start with that. It could also be the brake fluid sensor in the reservoir that is sticking and causing faulty readings. Either one could potentially cause two of your issues, otherwise it might be related to something in the braking system such as the brake booster or the ABS pump assembly. Rule out the mechanics first and then figure out if it is electrical.
Old Feb 19, 2016 | 09:38 PM
Very helpful, thanks for the help RedBull-1 and Turtlehead. I think it might be the brake fluid sensor as there's plenty of fluid in the reservoir.
I also learned that my car is included in the airbag recall, so another item to investigate with Honda.
proton8d
Sep 9, 2013 06:05 PM
tiotico
Jul 31, 2012 08:04 PM
dacecil
Jun 21, 2012 06:27 PM
daemon44
Mar 7, 2009 06:58 PM
DadofFour
Oct 10, 2007 06:34 AM
