check engine light on code is p1491
Old Apr 8, 2014 | 06:37 AM
vuuli312's Avatar
Default check engine light on code is p1491
Hello my check engine light came on. I pulled the code p1491 (using innova code reader). The booklet interprets this as "egr valve lift insufficient detected" . Can anyone tell me what this means, what I should be looking at, which component needs attention, replacement etc? Thanks in advance
Old Apr 8, 2014 | 05:01 PM
What year accord, model, engine size, etc... do you drive?
Old Apr 12, 2014 | 08:11 AM
vuuli312's Avatar
Default check engine light on code is p1497
Thanks for the reply. The car is a 1997 honda accord ex station wagon with the 2.2 l v-tec engine
Old Apr 12, 2014 | 09:21 AM
P1491 is EGR valve insufficient lift. This means ECM commanded EGR valve movement and detected insufficient movement. It can be a failed EGR valve movement, vacuum supply fault, vacuum switching valve fault, or faulty lift sensor. Usual reasons are loss of vacuum through damaged/missing vacuum lines or faulty vacuum switch valve.
There is a long diagnostic to run this to ground. I did not have the obd2 procedure for this model but did have equivalent Obd1 procedure (attached) from 1994 manual.
File Type: pdf
Old Apr 14, 2014 | 08:19 AM
vuuli312's Avatar
Default check engine light is on code is p1491
Thanks for the reply texas honda. I've started to diagnose using the hayne's manual. I'll post as i go along.
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
dhalla196@rogers.com
Mar 7, 2007 09:21 PM
BertMan
Jan 30, 2007 02:15 AM
2001 Accord VTEC
May 19, 2006 07:29 PM
