Check Engine Light FIX?
Old Jan 18, 2006 | 04:46 AM
AJ's Avatar
AJ
Default Check Engine Light FIX?
DOES ANYONE KNOW HOW I CAN GET RID OF THAT PESKY CHECK ENGINE LIGHT(CEL).
Old Jan 18, 2006 | 03:09 PM
lightshow's Avatar
Default RE: Check Engine Light FIX?
AJ you dont want to get rid of it you need to get whatever the problem is fixed. most of the codes will put the computer in limp mode, which just sucks cause your car will run like ****. an obd2 computer can be a pain but its intended purpose is to help figure out problems.
lightshow
Old Jan 19, 2006 | 01:21 AM
deserthonda's Avatar
ORIGINAL: AJ
is the lite on now ??? are you asking to clear the lite?? if lite not on ,,,why would you want to get rid of it ???it is there to warn you when something goes wrong with the car
what is the year and model ??
Old Jan 19, 2006 | 03:54 AM
lightshow's Avatar
desert its an 06 6spd im pretty sure
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
