Check Engine Light Issue
Old Jul 10, 2012 | 09:14 PM
bce1015's Avatar
Default Check Engine Light Issue
I just recently purchased A 94 Accord Ex coupe with the 2.2 vtec. The check engine light was on and I ran the diagnostics and it came back vtec oil pressure switch. I replaced the switch and started the car. The check engine light went off and after a few seconds of driving it came back on. I ran diagnostics again and the light just stayed solid. I don't know what else it could be... Any suggestions would be great. Thanks
Old Jul 10, 2012 | 10:05 PM
If you don't have the Honda service manual, go the the DIY "sticky" above to download it for troubleshooting. That code doesn't necessary just mean a problem with the vtec oil pressure switch.
You can test the vtec solenoid valve and clean or replace the filter screen for the solenoid valve, etc.
Old Jul 11, 2012 | 10:22 PM
bce1015's Avatar
If that's the case would it cause a solid check engine light in diagnostic mode?
Old Jul 11, 2012 | 10:29 PM
No. It sounds like something may be up with your ECU.
Did the check engine light turning on happen only once, or does it keep happening? Check the ECU fuse (10 amp) and the backup/radio fuse (7.5 amp in engine bay fuse box).
Old Jul 11, 2012 | 10:31 PM
The solid check engine light in diagnostic mode may mean the ECU is in safe mode. Try resetting the ECU by pulling the ECU back-up fuse (7.5A) in the underhood fuse/relay box; or disconnecting the negative battery cable for a short while.
Old Jul 13, 2012 | 02:44 AM
94ex915's Avatar
Almost A Senior Member
Originally Posted by xiaoshatongxue
I am looking at options of installing a LED third brake light inside the targa screen either top or bottom. I don't really want the hoop spoiler option and the coupe option externally at the top of the rear screen won't work on a targa.
Ummm?
Old Jul 13, 2012 | 07:40 PM
bce1015's Avatar
^ haha. I did all the suggestions stated above. Still doing the same thing.. Bad ecu?
Old Jul 13, 2012 | 08:18 PM
Very possibly is a bad ECU.
Old Sep 12, 2012 | 09:17 AM
Mer1's Avatar
Default Check engine light reset
I recently had this problem with my 94 accord vtec and got the check engine light to reset by reseting the maintenance button (using the car key) on the dashboard. Pulling the fuses didn't work but the dashboard reset did! Give it a try if you are still having this problem.
Old Sep 12, 2012 | 10:30 AM
accord1224's Avatar
Good Tip Mer1... I will write that one down
Brian B
