Check Engine light, Limp Mode.
Old Sep 26, 2019 | 03:48 AM
cosmojuicer's Avatar
Default Check Engine light, Limp Mode.
Hello everyone.
Here's my problem. The car will go into Limp mode **I believe based on my research**(check light, no rev over 3000rpm, needle jerking). It will come and go but here is what i believe triggers it: 1-After the car is running for a while(hot weather, heavy acceleration, up hill?). 2-more often triggered while running A/C and multiple accessories. Also when I turn the engine off during Limp mode, let it sit for about 10 minutes, go to start backup, it will crank for about 5 to 6 seconds before turning over. I have learned a trick to start it right up by turning key to the acc position then turn key back one, then up again and crank! starts right up. I'd like to note it usually goes back off Limp mode when the car has cooled down,not running for a while. I heard this may be alternator causing this, but i know there can be a bunch of other reasons. Any advice would help point me in the right direction. Thank You.
Old Sep 26, 2019 | 11:23 AM
The Toecutter's Avatar
Originally Posted by cosmojuicer
Hello everyone.
Is the check engine light on? Any codes present?
Old Sep 26, 2019 | 03:05 PM
Default getting codes
Yes Check light is on.Sorry for the delay was out all day. Here they are:
(P0302 MSFIRE No.2 CYLINDER)
(P1381 CMP SENSOR A INTERMITTENT INTERRUPTION)
(P0700 A/T SYSTEM MALFUNCTION)
(P1739 3RD PRESSURE SWITCH FAILURE)
Thanks any advice will be appreciated.
matthewtorres2323
Mar 18, 2015 12:49 AM
truballer328
Mar 18, 2014 03:42 PM
thumper44
Sep 22, 2010 05:02 PM
ronjr8102
Aug 31, 2010 07:05 PM
6genex
Oct 3, 2007 07:32 AM
