The check engine light is on, where do I start?!
Old Jun 24, 2007 | 08:18 PM
zero9243's Avatar
Default RE: The check engine light is on, where do I start?!
Are there any dangers running the car like this?
Old Jun 27, 2007 | 04:32 PM
zero9243's Avatar
So it says in the manual to remove this fuse for 13 seconds to reset something. Will that do anything do you think or for sure something needs to be replaced?
Old Jun 27, 2007 | 04:58 PM
hondadude's Avatar
No danger running the car with a code stored; but there will be a performance difference because the computer will run in default/limp mode.
Yes it is a good idea to remove the backup fuse and reset the ECU to see if the same problem happens.
No big problem changing a dist. 3-12mm bolts and a good phillips screwdriver, if you have to swap out ignitor. The shaft of the disthas anoffset tabso you can't install it wrong.
Old Jun 27, 2007 | 06:34 PM
zero9243's Avatar
hondadude thanks for the help! its so hard to find time to do all this car stuff (especially when you live in an APT and don't have a garage :-\ ) I'll have time to do this friday night or saturday night or sunday. I'll keep you posted.
Old Jun 27, 2007 | 09:54 PM
zero9243's Avatar
to avoid starting a new thread, heres another thing...
Before any of this started happening, when it gets hot out her car won't start. It will turn over as much as you want to let it, but will not fire up. If you go to start it, then wait sometimes 20 min, it will start.
Old Jun 27, 2007 | 10:21 PM
Distributor shaft... Yes, the blade is off-center, but if you get it backwards you CAN hammer it into place. DON'T force it. It should slide nicely into place.
Hot cabin = no start... Search for 'main relay' for descriptions. Probably something good in the DIY section, too. It's located sorta above driver's kick panel. Faulty solder joints go open when they're hot, then the fuel pump doesn't run.
Old Jun 28, 2007 | 04:32 PM
  #17
zero9243's Avatar
ORIGINAL: JimBlake
Awesome. Searched and found a good walkthrough for the main relay fix. Otherwise i have no idea what your first sentences are saying.
Old Jun 30, 2007 | 01:21 PM
  #18
zero9243's Avatar
So i did the main relay fix and now her car starts in very hot weather which is good. I took apart this thing that I thought was the backup fuse but I don't know. It was this small yellow box that was screwed onto the left side of the engine bay (as if you are looking into the engine bay from the front of the car). But I opened it up and it just had some whitish goo in it but i didn't see a fuse. Was this the right thing? The check engine light went off for about 20 starts....
Old Jul 3, 2007 | 06:40 AM
  #19
zero9243's Avatar
Was that the right thing to unplug?
HondaJess
Apr 20, 2013 09:14 AM
LydiaEmily
Sep 29, 2010 01:05 AM
bboy702
Dec 29, 2009 06:42 PM
elderfoster
May 25, 2009 02:44 AM
