Chipped ECU alternative
Old Jan 29, 2013 | 09:13 PM
  #31
Hamster108's Avatar
sounds like a vacuum leak tbh. It will trip up your MAFs and TPS. Sluggish throttle response, high idle. Use a vaccum gauge with your MAP sensor to determine whats happening.
Old Jan 29, 2013 | 09:59 PM
  #32
RobinsonRicer's Avatar
wouldnt i get a lean code eventually? I havent gotten one. I tried checking for leaks with a propane torch too. nothing.
But maybe a leak when the vacuum is being drawn. something is leaking then, like a bad check valve on one of the hoses?
Old Jan 29, 2013 | 10:34 PM
  #33
Hamster108's Avatar
plug brake booster hose into vacuum gauge while car running, check voltages. Report back.
Old Jan 29, 2013 | 10:44 PM
  #34
into vacuum gauge? I could plug the brake booster and take absolute manifold pressure readings from the map sensor and compare
live2rice
Sep 20, 2012 02:26 PM
jgryz450
May 27, 2012 01:53 PM
live2rice
May 11, 2012 11:42 PM
pbplayer257
May 5, 2010 10:20 PM
mbo1985
Oct 19, 2006 12:48 AM
