Christine Accord (Electrical Issues)
Old Mar 11, 2014 | 02:23 PM
Pete J. Thompson's Avatar
Default Christine Accord (Electrical Issues)
I have a 2006 Honda Accord, 4 cyl. When the car is off and just sitting there, the radio will come on and off all on it's own. Also the light in the radio works only once in a while. I'm not certain what could possibly make this happen like that, but It scared the hell out of me when I go to get in my car at 5am and the radio blasts on for a moment. Today, it must have been doing it all night because my battery was really weak, and needed a jump to get it started. When I tried to start it all my dash lights were flashing on and off, it was pretty creepy.
Little help please????
Old Mar 11, 2014 | 03:34 PM
Pull fuse 32 in under-dash fuse box (driver's kick panel). This should disable radio and prevent radio from coming on w/ keyswitch OFF. If this test confirms power was being supplied w/ keyswitch OFF, then replace keyswitch electrical assy.
Defective keyswitch assy is common honda problem.
Old Mar 11, 2014 | 08:35 PM
Well, I kept the radio off all day and since I had to jump the car this morning, I haven't had any issues all day with it starting up. I didn't have to pull the fuse, as the radio will only come on when I leave it on before I shut the car off. It started with the light in my radio not working about a year or so ago, and it has progressively gotten worse with the radio. Some times when I am driving, and the radio is on, Ill hear a loud audio "pop" and the radio will quit working all together. If I shut it off and turn it back on it will work again. Could my audio system be shot???
Old Mar 12, 2014 | 07:46 AM
From your description it would appear to be an internal radio fault.
Replacement w/ a used unit is low cost solution. Check car-part.com and ebay for replacements.
05 Accord AZ
Sep 10, 2012 12:51 PM
shizoma
Apr 9, 2012 12:51 PM
cander71
Nov 19, 2011 10:49 PM
nogood25
Oct 16, 2011 02:15 PM
honsolo
May 19, 2006 03:18 PM
