Cl7
Old Dec 13, 2023 | 05:11 PM
Anthoney's Avatar
Default Cl7
Hey guys. I have a 2007 honda accord cl7 that I recently converted from auto to 5 speed manual. I got a k-tuner ECU and plugged it on. Now my issues are, the rpm is not passing 3000 and the gauge cluster isn't working. Any suggestions?
Old Dec 13, 2023 | 10:20 PM
This almost has to be an issue with the wiring/signals to the PCM. I'm not sure what could be the cause. Check for codes to see if the K-tuner ECU is not detecting a signal from a required sensor to give you some direction. Maybe reach out to K-tuner to get a pinout. You'd probably need the OEM pinout for the PCM with the original setup.
timl1066
Nov 1, 2021 02:58 PM
nolen10
Jul 31, 2019 01:04 PM
ZJS
Sep 12, 2017 02:43 PM
litz
May 7, 2011 01:12 PM
lost_identity81
Aug 1, 2009 05:43 PM
