Cleaning EGR Ports on 2.7 V-6
Old Feb 14, 2010 | 07:23 PM
Eaglefixer's Avatar
Default Cleaning EGR Ports on 2.7 V-6
My friend has a 1995 Honda accord EX with 2.7 V6 engine. I have looked for some info on cleaning the egr ports on this motor but can't find it. I have found some info on the 4 cylinder and the newer v6's but no this one. Can someone please tell me how to do this please.
Thanks
Steve
Old Feb 14, 2010 | 09:38 PM
You'll get better luck in the General Tech area, so I'll move this.
Old Feb 14, 2010 | 09:57 PM
#5 and #6 are the EGR cover and gasket (i would suggest getting a new gasket).
The ports should be right on top of the manifold.
Old Feb 14, 2010 | 09:59 PM
Eaglefixer's Avatar
thanks for the pic. What should i take off to get to the EGR cover?
Old Feb 14, 2010 | 10:29 PM
I've never worked on a V6.
I would guess that you will have to remove the plastic cover that has V6 24valve. There shouldn't be much between that cover and the EGR plate to remove.
Old Feb 14, 2010 | 11:41 PM
Eaglefixer's Avatar
Hey thanks for the help. I did remove the plastic cover and there it is. Had to take a few other bolts out from the power steering pump hose on top and the hold down bolt for the same hose. Took the EGR cover off and man what a mess. I cleaned some out tonight but will clean it good tomorrow for sure. Just want to say thanks again. I'll try and post some pic's tonight or tomorrow.
Steve
Old Feb 16, 2010 | 06:22 PM
bauer007's Avatar
https://www.hondaaccordforum.com/for...ad.php?t=30832
If after cleaning the EGR plate/port and/or the valve and have any problems resetting the check engine light or "code" issues with the radio check this link.
klrspz
Oct 11, 2012 11:38 AM
Mikebike125
Feb 24, 2010 07:57 PM
geekracing
Jul 18, 2008 05:19 PM
jimbrown618
Jun 21, 2007 08:30 PM
deserthonda
Jun 21, 2006 05:18 AM
