Clicking near fuse box 87 accord dx
Old Jul 12, 2016 | 02:37 PM
  #21
oldtimewine's Avatar
Power wire is yellow
Ground is black
Old Jul 12, 2016 | 04:21 PM
  #22
Don't forget to check for a loose/flaky ground wire.
Old Jul 12, 2016 | 06:51 PM
  #23
If this were my car, I'd backprobe the yellow wire at the fuel pump. Verify that you are losing voltage to the pump. If yes on voltage loss to the pump, then I would back-probe the yellow wire at the fuel relay. See if the wire has a constant 12V when the fuel pump runs and what happens to the voltage when the pump cuts out.
I'd use a bare metal bolt for ground during this round of testing.
Your next step will depend on your results.
Old Jul 12, 2016 | 08:38 PM
  #24
How done find a wiring diagram for 1987 accord dx? My book (haynes) is not very informative when it comes to this. Maybe I'm looking at it all wrong.
Old Jul 12, 2016 | 08:40 PM
  #25
At the pump, the original ground wire is still connected. Is it possible it could still be loose even though it's working as a ground for my current rig with the switch?
Old Jul 12, 2016 | 08:43 PM
  #26
The hondahookup site in this thread has an 86 shop manual that you can download.
https://www.hondaaccordforum.com/for...-manuals-4597/
Old Jul 13, 2016 | 09:19 AM
  #27
Yeah, I think you're right, it seems like that shows it to be OK. But it's easy to wiggle it around & check it.
Old Jul 14, 2016 | 09:54 AM
  #28
Now the car doesn't idle too well often dying when warm. I'm thinking it's bc I by passed the relay and went straight to the battery ,Thoughts?
Is there a way to run the hot wire from the pump to the relay, then to the battery eliminating the need for the switch? This relay has 4 pins in a row labeled 1 2 3 4....I'm not sure which pin belongs to what..
Old Jul 15, 2016 | 10:51 AM
  #29
I'm traveling so I don't have all of my manuals with me.....so I'm going on memory and this one pic I have saved on my computer.
If pins one and two are connected, you are jumping the relay - taking it out of the circuit.
Attached Thumbnails Clicking near fuse box 87 accord dx-3rd-gen-fuel-relay-jump2.jpg
Old Jul 16, 2016 | 06:47 AM
  #30
I'll give this a shot on monday.
I'm living in Missouri at the moment and when it gets hot(90 + degrees)outside the car won't hold a steady idle. Strange enough in the early morning or late evening it runs great. Any clues as to why?
arragnod
Apr 5, 2013 08:53 AM
snk9950
Oct 8, 2011 06:31 PM
tvandentop
Sep 17, 2011 06:42 AM
IAAccord95
Oct 25, 2005 09:45 PM
