Climate control 01 accord
Old Jun 26, 2020 | 11:46 PM
Bhody837's Avatar
Default Climate control 01 accord
Question..... so my old climate control broke so I bought a replacement from a scrap yard. The new one only works when I hit it or hit a bump and it only works for a second, I looked online for a quick fix and I ended up soldering a wire into the motherboard of the climate control, still nothing.
I installed an aftermarket radio and spliced the wires when I did it. My new radio didn't have a wire to connect my red/black dimmer wire so I capped it off
It also doesn't have anywhere to hook up my red wire which I believe Is my ignition switch wire or illumination wire. Where do I hook up these wires? And is my climate control effected by all of this? I already replaced all the fuses checked the relays and the connections and everything seems to be connected fine I dont know what to do. Any suggestions?
Old Jun 27, 2020 | 07:51 PM
You probably won't get many responses, since this is an aftermarket radio installation. Can you let us know a part number for the aftermarket radio you are installing?
karter25
Jan 18, 2012 08:06 AM
jhamilton
Jun 19, 2011 11:56 PM
JDMb16crx
Sep 11, 2008 09:34 AM
mikebrawn1
Mar 28, 2007 12:23 AM
gravey86
Jan 30, 2007 09:38 PM
