Clockspring
Old Mar 17, 2019 | 08:09 PM
D23vorobey's Avatar
Default Clockspring
How do I reset the clockspring on my 2004 Honda Accord
Old Mar 17, 2019 | 09:13 PM
What work did you do on your car that you have to replace the clock spring? The procedure will depend on what work was done.
Old Mar 17, 2019 | 11:33 PM
D23vorobey's Avatar
I swapped the subframe so I had to pull the steering knuckle apart
Old Mar 17, 2019 | 11:58 PM
If you didn't turn the steering wheel, and the wheels are aligned in the same place from when you removed the steering rack, then you shouldn't have to set the clock spring.
You can damage the clock spring if you turned the steering wheel or shifted the rack & pinion when you did the install.
I think you have to have the steering wheel and the tires pointed straight, remove the steering wheel, then turn the clock spring clockwise until it stops, then counterclockwise about 3 turns. There should be an arrow that should be pointing up. Then your reinstall the steering wheel.
Northernmaine
Feb 21, 2014 05:26 PM
jayaccord
Jun 7, 2012 10:29 AM
fireblast713
Nov 1, 2010 02:06 AM
VTach
Oct 29, 2006 09:39 PM
