Clutch?
Old Jan 29, 2009 | 06:49 PM
Azrael's Avatar
Originally Posted by finch13
It's on transmission housing directly below the thermostat housing. Pretty much in the back.
Well, I'm pretty ignorant in that area of the car hence my previous problem with the clutch. Any details of what im looking for would be great. SIze, shape, your probably gonna have to explain like Im a old lady or young child or something. :P
Old Jan 29, 2009 | 07:05 PM
finch13's Avatar
Um... its black... i wish I had a picture. Basically, find the place where the upper coolant hose goes, look down at the transmission, it's literally right below it, but difficult to access. I'd take it back to the shop and say "Hey, my car hits the rev limiter now and I have good reason to believe it's the VSS. Since it didn't do it before, you should clean it for free."
Old Jan 29, 2009 | 08:04 PM
Azrael's Avatar
Ok, So I went out to my car and looked around the area that you describe and the was this little clip. I thought to myself this cant be it, too easy. But sure enough I pressed it down a lil and......CLICK. I doubted that I had done anything other than click a loose cable for something that had no relevance to what I was trying to do. I jumped in and hit it down the street. 2000>3000>4000>5000>5500 no problem. Much thanks friend!
Old Jan 29, 2009 | 08:20 PM
finch13's Avatar
Wow, very nice! What is tough to get too?
Old Jan 30, 2009 | 06:08 AM
Azrael's Avatar
Not really. Only if you have hands like a cabbage. :P
Old Jan 30, 2009 | 10:18 AM
finch13's Avatar
Haha. I must then... of course I took mine out instead of just reconnecting it.
Old Jan 30, 2009 | 08:44 PM
  #17
Azrael's Avatar
It was actual not in a bad spot at all. I could reach right in the back of the engine bay and sneak my hand over to it.
Old Feb 8, 2009 | 02:14 PM
  #18
Azrael's Avatar
It's been almost 2 weeks since I had my clutch fixed and its slipping again. Any thoughts. Sometimes it runs fine but the others it slips every gear. Once it starts doing it, it wont stop untill i cut the car off for a while the try driving again.
Old Feb 10, 2009 | 05:24 PM
  #19
Azrael's Avatar
Update....Clutch is slippin not two weeks later. I turned it back into the shop. I did notice however that the rubber on the front motor mount was split all the way around the middle. I researched that that could have an affect on clutch performance. Any thoughts?
Old Feb 10, 2009 | 05:26 PM
  #20
finch13's Avatar
Have the shop replace the mount, then replace the clutch free of charge. They probably put in crap. I would pay the difference between what they put in and a Honda or Exedy Stage 1 clutch is.
