Clutch replacement 93 accord
Old May 30, 2013 | 10:50 PM
toyhonda's Avatar
Default Clutch replacement 93 accord
Hi,
I need to replace the clutch in my 93 5-speed EX.
While I have the tranny and motor separated is there any additional maintenance that I should perform?
Thinking about the way we do the water pump and oil seal while replacing the timing belt; is there a similar routine at the other end?
Thanks
Old May 31, 2013 | 12:03 PM
Please read rules in New Member area. Don't post in the DIY forum.
Only recommendation I would make is not to touch the crankshaft seal unless it's leaking. It's easy to create a problem where none exists.
Perhaps replacing flywheel w/ new or machining old flywheel comes to mind along w/ all maintenances associated w/ clutch replacement.
If there are any problems w/ trans; worn synchronizers, loose linkages, it would be good to address these.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
yamahonda06
Apr 5, 2006 12:45 PM
