Code 14 honda accord
Old Mar 15, 2013 | 06:05 PM
qvohuerta's Avatar
Default Code 14 honda accord
My car was running good then all of sudden it die on me,,,,,, so I change the main relay and it started got home and shut of again so now im able to warm it up and shuts down I don't get any power to my fuel and my sparks so that's when I got that code 14 is that something wrong with the TCU or the ECU
Old Mar 15, 2013 | 06:42 PM
is the code 14 from the D4 or the check engine light?
Old Mar 15, 2013 | 08:02 PM
qvohuerta's Avatar
its from the d4 its funny its like it takes a break lol and then I get power all over again and then it starts but a minute passes by and turns off
Old Mar 15, 2013 | 08:22 PM
I have one more question. What year, model (EX,DX,LX) is your accord? 4/6 cylinder as well.
Old Mar 15, 2013 | 09:14 PM
qvohuerta's Avatar
oh its a 95 lx 4 cylinder
Old Mar 16, 2013 | 12:04 AM
A code 14 from the TCU indicates an ECU problem. ECU is likely the problem (it could be a bad TCU).
You will need an ECU from a 94/95, LX/DX, Automatic Transmission accord. These are easy to install and used ECUs can be found at junkyards or U-Pull-It yards.
Old Mar 16, 2013 | 12:30 AM
qvohuerta's Avatar
oh ok thanks I would pick one up tomorrow and will post the outcome would does have to be program
Old Mar 16, 2013 | 07:58 PM
qvohuerta's Avatar
Default 1995 honda accord need ECU
IM LOOKING FOR A ECU THAT WOULD WORK FOR MY CAR MY OLD ONE WAS 37820-P0J-L50
385-102805
its a 4 cylinder non vtec and believed is a LX
do I need to get one the same or get it program
Old Mar 16, 2013 | 09:59 PM
Your accord is California emissions. You should get the ECU from a 95 LX accord with an automatic transmission.
That is the only accord that has that ECU part number.
You do not need to program that ECU, because there is no immobilizer (or Rf chip in your key).
Old Mar 21, 2013 | 01:53 PM
qvohuerta's Avatar
ok I put a used ecu and tcu from the same Honda now it turns on good but I get a check engine light now and I get 9 blinks any clues thanks
