Code 14 honda accord
Old Mar 21, 2013 | 02:15 PM
qvohuerta's Avatar
ok I put a used ecu and tcu from the same car to Maine now it turns on with no problem now my check engine turns on with 9 blinks any clues
Old Mar 21, 2013 | 02:20 PM
qvohuerta's Avatar
Talking check engine light blinks
I put a used ecu and tcu from another Honda cause one of Maine was not working so I replace both of them just to make shore so now it turn on wich is great but now I get a code 9 from my CEL LIGHT any clues
Old Mar 21, 2013 | 02:43 PM
firefighter44's Avatar
Almost A Senior Member
I count 3 posts in tech help asking the same question, please limit your self to one post per "issue" and be patient in waiting for a response.
As for the code ( i may be wrong) but i believe its cyp sensor
Old Mar 21, 2013 | 02:55 PM
qvohuerta's Avatar
oh ok and what does that mean or to fix it
Old Mar 21, 2013 | 03:09 PM
CYP sensor. That's usually located in the distributor, but I don't know what car you're talking about.
Old Mar 21, 2013 | 03:22 PM
I believe your talking about a 95 lx correct?
It should be cylinder 1 position sensor.
Old Mar 21, 2013 | 03:27 PM
  #17
1995 there's 3 sensors down inside the distributor; CYP, CKP, & TDC.
Officially, they're not replaceable - you replace the whole distributor. But I've heard of people replacing them somehow. Maybe swapping from a junkyard distributor?
That code 9 means the signal isn't right. Might be a bad sensor. But also might be loose/dirty/corroded wiring connections or a broken wire between the distributor & ECU. You need to rule that stuff out or you might find that a new distributor doesn't fix it.
I think the signal wires for those sensors are shielded, just so you're aware of that before you start splicing wires.
Old Mar 21, 2013 | 03:35 PM
  #18
you said you just replaced the ecu, i would start by checking the signal at the ecu to make sure it is correct
Old Mar 21, 2013 | 05:04 PM
  #19
This is going to read a bit funny as I have merged the multiple threads on the same issue together.
Khai Son
Mar 14, 2012 11:32 PM
Rtherres
Jan 30, 2011 04:58 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
