code 9
Old Jan 24, 2008 | 06:03 PM
papaschilling's Avatar
Default code 9
my 1994 accord 2,2 lx runs great but engine light comes on sometimes, Diagnostic code is 9 which is a cylinder position sensor. Any suggestions?
Thanks
Old Jan 24, 2008 | 06:20 PM
Default RE: code 9
YourCYP sensor is inside the distributor, & can only be replaced by replacing the distributor. First check the plugs at the distributor, for loose/dirty/corroded pins, loose wires, maybe some wiring that has rubbed thru the insulation, etc...
Then take off the distributor cap & rotor. Down deep inside, there's star-pointed things on the distributor shaft with magnetic sensors reading the points of each star. One of these is the CYP sensor. Look for magnetic crud sticking onto that stuff; clean it up.
If the inside of the distributor is filled with rust-colored dust, then the bearing's shot. Get a new distributor.
Rule out the simplestufffirst before getting a newdistributor$$$. If it only happens occasionally, I don't know what to tell you about how to guess how long before it gets serious.
Old Jan 25, 2008 | 11:56 AM
Default RE: code 9
Thanks for your help. I appreciate your suggestion wnd will try to clean that area.
usmrocks
Nov 28, 2010 09:32 AM
tingjunkie
Sep 17, 2010 06:37 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
