Codes 4 & 9 - Won't Start
Old Apr 11, 2011 | 09:49 AM
litz's Avatar
Default Codes 4 & 9 - Won't Start
91 Accord, 90,000 miles.
Was driving home over the weekend, check engine light came on, started to sputter and run really bad. Made it home and now it won't start.
Checked the codes and it blinked a 4 and a 9. From what I researched this is a crank sensor and #1 cylinder position sensor.
The car has been making some sounds for the last little while... sounded like a bad bearing in the top of the engine compartment but i could not pin point it. A high pitched squeal... but not constant... more off and on.
Old Apr 11, 2011 | 12:18 PM
These two sensors are located inside the distributor. Distributor bearing may have failed. I've heard of distributor bearing failure in thie generation Accord.
You should pull the distributor,and try turning by hand. It should turn easily and smoothly. Any grinding or wobbling of shaft(this causes sensor failure) will be reason to replace the distributor. In principle it can be repaired, but rebuilt distributors are readily available online (ebay, amazon, rockauto) at very reasonable prices; $100-$150.
Old Apr 13, 2011 | 11:51 AM
litz's Avatar
Thanks,
Replaced the distributor and it's running good again. No CEL.
The only weird thing is the RPM gauge jumps around now and there is a slight scratching noise from under the hood. Hope this new distributor is not faulty. Is that where the RPM gauge is connected to?
Old Apr 13, 2011 | 11:59 AM
RPM signal is generated by the ignitor module in the distributor. Did you have this symptom earlier?
Are you spark plug wires in good shape? Spray the wires w/ healty dose of fine mist of water at night and look for sparks. Any sparks suggest new wires.
If plugs are over 60K miles, suggest replacing them.
Are you experiencing in missing while rpm is fluctuating?
Old Apr 13, 2011 | 04:37 PM
litz's Avatar
This symptom is new since replacing the distributor. The RPM gauge jumps all over the place even when the car is idling fine.
The wires are probably the originals. I did change the plugs last summer. However, the car was parked for the winter, last 6 months or so. So maybe the plugs just need a little cleaning.
No missing, seems to be running ok.
Old Apr 13, 2011 | 09:33 PM
RPM movement may be sticking. Hopefully will loosen w/ use. Sometimes a good "thump" will work wonders w/ mechanical parts.
Sheri6889
Jun 17, 2015 08:19 AM
drumdoctor
Jan 16, 2012 09:53 AM
Bcarte19
Dec 28, 2011 05:06 PM
JetJock
Jul 12, 2009 11:52 AM
