Compass Zone not being saved
Old Oct 28, 2017 | 10:20 AM
pcmassoc's Avatar
Default Compass Zone not being saved
This is my first post. I am having trouble with my brand new Accord Touring navigation system. I have discussed it with the dealer, and they are stumped as well. The nav system vehicle pointer is offset but parallel with my actual street, when pointed in the right direction of travel. The offset is in the order of up to 1/8 of a mile. Sometimes but not always, the nav map spins around every few seconds, and takes several miles of driving to "find me". This happens intermittently right after restarting the vehicle. Here is what I would like to pursue before returning to the dealer: I would like to reset the compass calibration zone to the correct one. When I go through the procedure shown in my owner's manual (pg 411, etc.), I select my zone (11), changing it from the existing zone "0" setting, and then calibrate (driving in circles, etc.). The CAL light never comes on. When I check the calibration zone again moments later, the calibration zone still shows as "0". My attempt to permanently save it to zone "11" is not being recognized. I have a suspicion that this condition (not being in the right zone) is contributing to the offset error. Any suggestions?
Old Oct 28, 2017 | 06:38 PM
I'm not familiar with the setup on newer accords. Is there something simple you are missing like hitting enter for the navigation system to set the zone?
Sounds like you will need to get the proper zone set in your system before doing any more troubleshooting. You should find out if the dealership can reflash the navigation system to make sure the software is running properly. They may be able to enter the zone using their honda scanner as well. Since it is a new car, they should take care of the issue.
Good luck.
rob axel
Oct 3, 2011 11:12 PM
BU50
Sep 24, 2008 09:40 PM
lost_ko
24
Jul 14, 2008 04:17 PM
embpilot
Nov 11, 2007 06:52 PM
homeline
Sep 17, 2004 04:25 PM
