Continuing my Vibration solution
Old Apr 12, 2006 | 10:17 PM
Markus26's Avatar
Default Continuing my Vibration solution
has anybody ever changed the valve that controls the hydraulic mount in the rear of the engine? i have been looking into this more and more, started leaning towards the motor mounts and figured id give it a shot here first. its a 97 2.2SE. im thinking my valve has gone bad. but before i go ahead and spend $40- id inquire.
Old Apr 13, 2006 | 06:05 AM
lightshow's Avatar
Default RE: Continuing my Vibration solution
i have never changed just that valve, but i have changed the whole mount before. are any of the other mounts broken?
Old Apr 13, 2006 | 01:19 PM
Markus26's Avatar
ORIGINAL: lightshow
all the mounts seem to be intact. i have the service bulletin from honda for the troubleshooting of this mount. this weekend i will give it a shot and let you know what i come up with.
Old Apr 17, 2006 | 01:59 AM
Markus26's Avatar
So the mount holds vacuum, and the control valve is also working. i did all the honda troubleshooting as per the service bulletin. they say to replace the mount. its pretty pricey so i will see how bad this vibration gets then ill go after it. for now i will just deal with it. ::end Rant:: lol
Old Apr 17, 2006 | 03:40 PM
sir_nasty's Avatar
Did you look online for the part or call a honda dealership? Just our of curiousity how much did they say the mount cost?
Old Apr 17, 2006 | 04:43 PM
deserthonda's Avatar
are the other motor mounts ok ??
Old Apr 17, 2006 | 04:51 PM
sir_nasty's Avatar
ORIGINAL: Markus26
ORIGINAL: lightshow
The other mounts appear to be okay...
Old Apr 17, 2006 | 10:30 PM
Markus26's Avatar
the mount is roughly $300- and that valve is about $50- ill probably change both just to be safe.
The honda bulletin i got from a friend that works for Honda.
Alone
Oct 22, 2014 07:43 AM
wrench
Oct 30, 2011 09:45 AM
rtmobile96
Sep 16, 2007 04:14 PM
Roadhead
Nov 13, 2006 10:49 AM
