Converting to FI from carb
Old Oct 11, 2013 | 06:08 AM
Hisankitsune's Avatar
Default Converting to FI from carb
I was wondering if its possible to retro fit an 89 accord with FI and if its worth it or just to buy a new car, i had a part go bad on the car this weekend that seems irreplaceable due to unavailability (Part Number 16210-PH4-662). I understand they generally cost about 1.3k average.
Old Oct 11, 2013 | 09:04 PM
It depends on what you want to spend to do the conversion. It would require a bit of work. If it were me, I would either find a used or aftermarket replacement part, or look fora replacement vehicle.
Old Oct 12, 2013 | 05:07 AM
i really dont care to spend what i have to, to keep the car but its infuriating that this part i need doesnt exist anymore. Ive tried tons of junk yard and cant seem to find this part. Back to the main topic i just wonder if its worth converting to FI and is it something you can do yourself or best left to a mechanic.
Old Oct 12, 2013 | 11:19 AM
The efe heater......just keep driving. Ok when the car is cold you have a small issue but once the car warms up you are fine.
Converting to FI - not worth it.
Old Oct 13, 2013 | 04:58 AM
So it would be alright to just not fuss with the heater working? If im not mistaken it is leaking as well though, like its not sealed properly. I replaced the gasket and seal when i replaced the carb though. If the insulator isnt nessecary though ill be glad to done with it.
Old Oct 13, 2013 | 06:51 AM
If you can verify no leaks, keep driving. If it is leaking, not at the gaskets but thru a crank in the heater grid......a few choices, seal the grid crack with epoxy/silicone.....search a few bone yards for a 3rd gen carb car, or just remove the grid?
Crazyguy
Jul 5, 2010 08:31 AM
Antarctica
Oct 15, 2007 11:00 PM
kaotikcariz
Aug 6, 2007 08:06 PM
honda212
Dec 11, 2006 01:36 AM
1a9c9c9ord
Nov 28, 2006 10:28 PM
