Coolant Disappearing
Old Sep 2, 2013 | 12:20 PM
hmr's Avatar
hmr
Default Coolant Disappearing
I have a 2000 Honda Accord EX sedan with 4 cylinder and A/T. Today I noticed that my coolant reservoir was empty and the coolant level in the radiator was down to the base of the neck. I have never noticed a coolant leak anywhere. What I did notice this morning is a splashed, whitish residue around the reservoir tank area. Doesn't appear to be any such residue around the radiator. I'm assuming that this residue is coolant. Any input on this situation would be greatly appreciated. Thanks.
Old Sep 2, 2013 | 01:56 PM
I would stop by a parts store and rent a radiator pressure tester. Check that your radiator holds about 15 psi.
Old Sep 2, 2013 | 04:34 PM
hmr's Avatar
hmr
I discovered a hairline crack in the plastic radiator casing. Coolant definitely beading up at this location. Do I have any repair options other than a radiator replacement ? Thanks.
Old Sep 2, 2013 | 07:23 PM
Any repair would be very temporary. Replacing the radiator is the way to fix this.
Old Sep 3, 2013 | 07:52 PM
That plastic tank can have brittle failure. I wouldn't trust a repair for much longer than the time it takes to order a radiator.
Old Oct 14, 2013 | 01:15 PM
chrisjames105's Avatar
I have a question about this topic as well. I have an all aluminum radiator that I installed after my plastic radiators kept cracking. I also installed a new thermostat straight from the Honda dealer at the same time. Lately Im noticing that coolant seems to be disappearing cause its never full. I dont notice any leaks.
Old Oct 14, 2013 | 03:03 PM
If you can't find the leaks then I'd get a tester so you can pressurize the cooling system cold. That way it doesn't evaporate as soon as it leaks, to help you find the leak.
Check the cap? How about the inner & outer seal lip in the radiator neck? Leaks there might cause it to overflow at the reservoir bottle, where you might not be looking for the leak.
Old Oct 14, 2013 | 08:52 PM
the cap actually keeps breaking i know that. didnt know what that could cause. the radiator cap keeps breaking though, the little piece on the inside of the cap, what causes that?
Old Oct 15, 2013 | 07:07 AM
Not sure I understand what "the little piece on the inside" really is. Take a close look at how that fits into the radiator neck. If the neck on the aluminum radiator isn't a perfect match for what the cap needs, then maybe that radiator needs a different cap? It still has to do the same job with the same 3 seals to control overflow, suck fluid back in during cooldown, and keep the air out.
dannyp1981
Jun 29, 2009 05:08 PM
hondafreak2
Dec 15, 2006 06:43 PM
5.0L Miata
Jun 5, 2006 10:45 AM
Jul 3, 2005 03:39 AM
habeel
Jun 14, 2005 10:16 PM
