Coolant recommendations
Old Aug 10, 2011 | 11:47 AM
tashier's Avatar
Default Coolant recommendations
Any special recommendations on coolant? In the past I've just used the green stuff. I think that's what it came with.
Old Aug 10, 2011 | 12:34 PM
As long as the "green stuff" is antifreeze, I think you're fine. I've not seen much difference in performance.
Old Aug 10, 2011 | 12:44 PM
Newer accords use coolant that last much longer than the green stuff. I would use what Honda recommends for your car in the owner's manual. BTW, put your year model, etc in your signature, so we know what car you drive.
Old Aug 10, 2011 | 12:51 PM
Opps, guess he didn't read your post on this one either..
Old Aug 10, 2011 | 03:06 PM
Most antifreeze problems come from mixing types that aren't compatible. If you rinse the system thoroughly so none of the old stuff remains, then you should be OK. The "green stuff" doesn't have the long lifespan of the Honda stuff, but if you change it properly you'll be OK.
Old Aug 10, 2011 | 04:29 PM
tashier's Avatar
It's there now!
Old Aug 10, 2011 | 06:45 PM
Thanks.
I would use the green antifreeze. Use a 50:50 mix. Change at the recommended interval.
The reason I asked the year is that newer accords have the long life coolant and you can't mix it.
I used the green stuff in my 95 and didn't have any problems. I think that you are supposed to change it at 24K miles. Check your owner's manual to verify.
jimsmith
Jul 13, 2006 05:43 AM
sir_nasty
Jun 14, 2006 11:28 PM
nixalot
Apr 20, 2006 07:38 PM
dinzer
Sep 6, 2005 01:04 AM
dinzer
Aug 7, 2005 03:26 AM
