coolant renewal
Old May 7, 2007 | 02:42 PM
accord4sroy's Avatar
Default coolant renewal
so, this is probably in the faq but i don't have too much time today to look at it. anyways, how often should your coolant be changed? according to the hood sticker when i checked it every two years? does that sound right? thoughts are highly welcomed.
thanks.
Old May 7, 2007 | 07:29 PM
Default RE: coolant renewal
I like to change it every 2 years regardless of miles.
You can measure the strength of the anti-freeze properties with a hydrometer (the little float thing). But what wears out is the anti-corrosion package, andTHAT isn't easy to measure.
Old May 8, 2007 | 01:26 AM
yeah, i have had to replace the radiator in my last car which was a pretty old car at the time. although, i come to the philosophy now that older is better after joining this forum a while back. it was indeed corrosion that ate up the last radiator, actually i went into the next shop (previous shop told me about the radiator, anyways when i went to do the coolant flush i said my radiator might not be up to par, luckily i did otherwise it would have been a waste to do a coolant flush). well close to 13 years for a new radiator isn't a bad life i guess for that last car.
but, honda's are awesome! this car i don't figure will have problems because i feel the like new drivability each time i drive it.
thanks for your thoughts.
Old May 11, 2007 | 12:34 PM
RogerB34's Avatar
Ph is the key reading.
Test strips are available.
Here's a link:
http://carfood.com/coolcooltess.html
Long life coolant around 8.3.
I'ts a different inhibitorthan standard coolant.
Honda only use Honda.
Otherwise I use long life and vending machine water (distilled ok too).
Vending machine uses reverse osmosis and other filters to remove undesireable characteristics of tap water.
dannyp1981
Jun 29, 2009 05:08 PM
hondafreak2
Dec 15, 2006 06:43 PM
5.0L Miata
Jun 5, 2006 10:45 AM
Jul 3, 2005 03:39 AM
habeel
Jun 14, 2005 10:16 PM
