Coolant tank leak
Old Jun 17, 2009 | 02:31 PM
zwizenator's Avatar
Default Coolant tank leak
Hi guys,
I got a 2005 v6 coupe. I'm no car expert but I'll try to explain the best I can.
On top of the coolant tank, there is a small black hose that leads out to the radiator area. Where the tank and the hose meet, I see what appears to be dried up coolant crusted up all around that area. My coolant level is pretty stable so its not a huge issue, but I wanna fix it. Is there possibly some sealant I could apply to the area?
Thanks!
Old Jun 17, 2009 | 03:13 PM
You'll need that little plastic fitting to spin, allowing you to unscrew the reservoir cap. Plus, there should be a small vent hole in the cap. Clean it up & see if it comes back.
Normally the proper level is far enough down in the reservoir, so it can expand with heat & still not spill out the top with normal driving & shaking.
bluedemon
Dec 14, 2014 10:58 AM
faran
Jul 14, 2013 01:55 PM
mclasser
Apr 4, 2013 07:38 AM
hondamecha
Jul 10, 2008 12:36 PM
vmac1
Jul 3, 2007 08:06 PM
