Cooling fan comes on when ignition is turned to “ON” position (not started).
Old Feb 6, 2021 | 09:58 PM
MeltySchmak's Avatar
Default Cooling fan comes on when ignition is turned to “ON” position (not started).
My engine cooling fan comes on as soon as i turn the key to the “ON” position without turning it to start. Any ideas on what might cause this? I don’t want my fan motor to burn out. Any help would be appreciated!
I’ve also saw posts on here where the fan stays on even if the ignition key is off. My fan at least shuts off when the key is turned to the “OFF” position.
***Update. I removed the cooling fan relay. and the fan still comes on. I also removed the condenser fan fuse and the cooling fan fuse but the fan still comes on. I also removed the fan-switch wire beside the upper radiator hose and the fan still comes on.
Old Feb 7, 2021 | 01:49 PM
Will you provide us the year, v6/4cyl, manual/auto trans, and trim of your car?
Old Feb 7, 2021 | 03:14 PM
Totally forgot to add that to the thread... sorry about that.
1994 Honda Accord EX
2.2L VTEC
5 speed manual
Old Feb 7, 2021 | 05:51 PM
Turn off the a/c on the center console and let us know if the fan shuts off.
Old Feb 7, 2021 | 06:50 PM
A/C was not on, but i did change the oil and the problem is now solved. I’m not sure what happened. Very strange.
Old Feb 7, 2021 | 08:03 PM
If the a/c is shut off and the problem returns, then you will next unplug the green two wire connector near the thermostat housing and let us know what happens.
hlockquiok
Dec 14, 2017 09:55 AM
Coachscott
Aug 23, 2015 06:29 AM
mikez
Jul 26, 2013 05:32 PM
peter woo
Sep 28, 2011 12:20 AM
RSM93HONDA
Jul 14, 2007 10:55 PM
