1994 radiator fan
Old Aug 22, 2015 | 11:05 PM
Coachscott's Avatar
Default 1994 radiator fan
My fan motor melted away from the fan. Yes I can show pictures. I replaced it and after doing that I went for a drive and the new fan never kicked on. The car ran warmer than usual too. Why didn't the fan kick on?
Old Aug 23, 2015 | 06:29 AM
Turtlehead's Avatar
I suggest checking the connector for damage. Then with the key in the on position, car not running, turn on the A/C and cabin air fan speed to high. Do both fans turn on? If only the A/C fan turns on then check the fuses. Are the fuses OK? If so, check the fan relay switch. If these steps don't solve the problem there are other potential causes.
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
JoeAsheville
Aug 26, 2007 11:13 AM
daddy
Feb 6, 2006 02:52 AM
