1994 Accord DX F22B2 KH Model - Radiator fan inoperative
Old Aug 26, 2007 | 10:55 AM
JoeAsheville
Default 1994 Accord DX F22B2 KH Model - Radiator fan inoperative
After a lengthy diagnostic procedure I have determined that there is inadequate ground signal at the plug to the radiator fan. I'd like to get things back to the way they were stock instead of just jumpering over from the ground at the plug to a screw on the chassis...so the diagnostic manual on this site leads me to beleive that G201 may be intermittently bad (blinkers operate erratically so that may be the culprit there also). The car has been hit by a deer on that side (dented fender about 4 inches) so I'm leaning in the direction of a dislodged ground. However even after examining the diagram I can't find G201 on the car. Is it behind the plastic inner fender, behind the bumper, or under the battery?
Other threads will be made about other problems with the car...similar title. Please let me know if you think all this is related somehow.
Old Aug 26, 2007 | 11:05 AM
deserthonda's Avatar
Default RE: 1994 Accord DX F22B2 KH Model - Radiator fan inoperative
g 201 is located below the rt headlite ,,comes off a wiring harness there are about 3-4 black wires going into a plug,,,you might want to chk the harness for damage,
Old Aug 26, 2007 | 11:13 AM
JoeAsheville
Roger that, will check for damage as well as a loose ground at that location when I am at the unit again.
SVTMike
Jun 2, 2013 10:51 AM
Novaknowledgenow
May 30, 2013 08:58 PM
madsteez
Oct 28, 2008 09:27 PM
JoeAsheville
Aug 26, 2007 02:14 PM
JoeAsheville
Aug 26, 2007 11:51 AM
