Cooling fans don't work 98 accord 4cyl
Old Sep 4, 2015 | 03:53 PM
Karl Pilichiewicz's Avatar
Exclamation Cooling fans don't work 98 accord 4cyl
please help! i have checked relays, fuses, jumped relays and fan turns on, jumped cooling fan switch and both fans turn on, applied direct power to fans they turn on, replaced cooling fan switch won't turn on, replaced coolant temp sensor still nothing. Turned on ac fan won't kick on. Everything I have done still didn't fix the problem. I don't know what else to do
Old Sep 4, 2015 | 06:18 PM
The next step would be to unplug one of the fan relays. The two bigger pins that are usually made of copper power the fan (sounds like you already jumped them). The other two pins control the relay. One pin should have 12V to ground (use a valve cover bolt as a ground). The other pin should be open to ground when the a/c is turned off. It should close to ground when the a/c is turned on.
Does the compressor clutch engage when you turn on the a/c?
Turtlehead's Avatar
If it is a 4cyl did you drain the air through the bleeder located next to the thermostat? The other quick diagnostic thing you can do is look in the under hood fuse panel and note the number on the relay, there should be another relay in there with the same part number on it. Swap them! If the fans work then you have verified that it is a relay, but please note, where ever the bad relay went that circuit will no longer work, thus replace immediately. Best of luck.
Old Sep 5, 2015 | 11:51 AM
Thank you guys! I will check all your suggestions as soon as I am able. I will update as soon as I do it. Thanks again
mishakol129
Apr 7, 2013 06:48 AM
ac398
Feb 15, 2010 11:48 AM
Jeebus
Jan 29, 2010 07:30 AM
myrsaccord
May 2, 2008 01:04 PM
Fredi95EX
Jun 16, 2005 11:07 AM
