Cooling and Radiator Fans not coming on even with A/C switch to ON
Old Jun 20, 2011 | 04:27 PM
pab59y's Avatar
Default Cooling and Radiator Fans not coming on even with A/C switch to ON
I have a 1992 accord, both of my fans will not come on even with the a/c switch to on. I jumpered the fans throught the condenser relay connector ylk/blk and red, and both fans will come on when I turn the A/C switch on. So, I think the fan motors are okay. I checked the no. 2 fuse and it is good. I am lost as to what is wrong? Any help would be appreciated!
Old Jun 20, 2011 | 04:28 PM
When you switch the a/c to on, does the clutch plate in front of the a/c compressor pulley engage and spin with the pulley?
Old Jun 20, 2011 | 04:35 PM
pab59y's Avatar
I think it does. The whole pulley seems to be spinning when the engine starts.
Old Jun 20, 2011 | 05:36 PM
Got to YouTube.com and search XU_A4wNuHXI
This is a video on a basic a/c performance test. About half way through the video, he shows the a/c pulley and how the clutch plate should engage.
Old Jun 20, 2011 | 06:15 PM
pab59y's Avatar
Thank you, PAHonda.
What does it have to do with the fans not working, just curious. The fans do come on when I jumpered the connector. I am just a novice, but just curious.
Thanks!
Old Jun 20, 2011 | 06:45 PM
pab59y's Avatar
Hi PAHonda,
I watched the video and checked a/c compressor pulley. It did not engaged when the A/C switch is on.
Old Jun 20, 2011 | 06:52 PM
phatboyslim2012's Avatar
hey, i had a similar well bassically the same issue!
so what i was told, is let car idle 10-15 minutes, the rad fan "passenger side should turn on, if it doesnt and the temp guage goes higher than usual, you have an issue.
my car was not running either fan, at any temp, even with the ac on, turned out that my a/c high line has a pin hole in it and the a/c refridgerant leaked out and stopped the a/c from engaging there for the fans would not spin, as for why the fans dont run when the car got warm was the temp switch A, it controls when the fan comes on. look at your service manual for the location, and jump the wires if the fan comes on then its the switch, very easy to replace, and only takes 10 mins to install!
Is heater blower coming on and running in any fan speed position? If not, the blower switch may be open or blower ground (G401/402 on 90 Accord) may be cut/damaged/corroded. This would disable the AC.
Old Jun 20, 2011 | 06:56 PM
hey texashonda,
i believe he is refering to the engine cooling fans and not the heater fan. good looks though.
Old Jun 20, 2011 | 07:36 PM
pab59y's Avatar
Okay. Just tested the A/C Pressure switch and jumpered it. Both fans came on and the compressor clutch did engage. So, any ideas?
