crank pulley
Old Dec 18, 2006 | 09:31 PM
brayner's Avatar
Default crank pulley
I'm finishing up a timing belt with all the trimmings- thanks to all the great help and info on this forum- and I'm not sure if this crankshaft pulley I have is going to work O.K. We knocked a small chunk out while removing the crank pulley bolt. My son says this won't make any difference and I'm not sure. Any opinions or experience with something like this?
[IMG]local://upfiles/6579/76018A74E9D345678A76F0ED454DF7DB.jpg[/IMG]
[IMG]local://upfiles/6579/73BB4D50EE65450EBFD7882CB00802C9.jpg[/IMG]
Old Dec 19, 2006 | 01:43 PM
sir_nasty's Avatar
Default RE: crank pulley
I would think that you'd be ok... there is always the possibility that it'd give you a minor wobble and take out a bearing... If you have the time I'd just go to www.spaldings.com (junkyard) and order another one or go to a local junk yard and get one... or upgrade it with an aem or unorthodox racing lightweight pulley... But I personally have never delt with this so I'm just speculating, chances are you'd be fine but if you've got the time I don't think it'd cost to much or take that long to replace it so why risk it?
Old Dec 19, 2006 | 02:30 PM
Hard to tell from the picture, but I think what's important is whether any sharp edges from the fracture are gonna chew up the belt as it spins.
The missing part looks pretty small & close to the center so balancing is probably OK.
Old Dec 19, 2006 | 02:41 PM
brayner's Avatar
thanks guys- I'll pick one up from a junkyard and put in on soon. Right now I'm anxious to see how the car runs. We only had in 3 or 4 days before the oil seal blew. Yes, this 1994 had never had the retainer upgrade put on.
Old Dec 19, 2006 | 08:18 PM
hondadude's Avatar
Smooth off the surface that will contact the P/S belt with a triangle file, then run it.
I've seen this type of damage many times and it doesn't cause any problems
swordfish7769
Nov 21, 2008 10:44 PM
imjrk
Dec 14, 2007 09:51 AM
ckebottle
Nov 22, 2007 03:01 PM
accordfan222
Oct 14, 2007 07:19 AM
dnask8ter
Mar 14, 2007 02:20 PM
