Crankshaft Pulley Bolt..... Need help
Old Mar 23, 2008 | 12:46 AM
DeVoe41
Default Crankshaft Pulley Bolt..... Need help
I need some help trying to get the crankshaft pulley bolt off of an 01 Accord 2.3.
Using a Strap wrench has not helped, I don't know if I can use an impact as I have the balance shaft secured with an allen wrench. I am looking for any helpfull hints or tips to get this thing off with out screwing anything up. I'm not use to Honda's so I'm in need of any advice. I don't care if it's yes stupid use an impact, or try this out. I just need any info I can get.
Thanks in advance.
Old Mar 23, 2008 | 01:47 AM
BlkCurrantKord's Avatar
Default RE: Crankshaft Pulley Bolt..... Need help
You need the tool at the bottom
http://www.tasauto.com/Product/Brows...;h=111&p=1
Autozone, Advance would be able to get it for you as well as your dealer.
Old Mar 23, 2008 | 02:26 AM
oma93's Avatar
If you car is a manual transmission just put it in 5th gear, have someone hold the brakes on, then use a breaker bar and a cheater pipe. Works just fine if you don't have a good impact. Not sure you could do this on an auto trans without damaging something.
Old Mar 23, 2008 | 03:44 AM
finch13's Avatar
You can hold the pulley with a chain (not strap) wrench and then use a breaker bar like oma said. Some people will disagree with me and say that the strap wrench will chew up your pulley, which is possible. I used a strap wrench that sat on the edges of the pulley, not on the ridges where the belt goes....
Your car is fairly new so an impact might work, but most people need to use an impact capable of 550+ ft. lbs. of torque.
Old Mar 23, 2008 | 09:12 AM
If you stuck a rod into the balance shaft to hold in position, remove before attempting to break the crankshaft bolt. It may shear and leave a piece of the rod stuck in the balance shaft. Rod through the balance shaft cannot restrain the engine since it's driven by a cogged balance shaft drive belt.
An impact wrench is your best bet, but may not work either. A good Ingersol Rand, plenty of air pressure/volume, a short hose, w/ only the impact socket on the impact will give best chance.
Save yourself a lot of money and buy a manual. Trying to do a timing belt job w/o a manual is asking for problems.
This is a fairly challenging job, and the crankshaft pulley bolt is the toughest part. It has defeated many.
Old Mar 24, 2008 | 08:05 AM
JeffB's Avatar
ORIGINAL: BlkCurrantKord
Or do what I did. Save yourself the time waiting for delivery, the cost for the part that you may never use again, and the skinned knuckles trying to get leverage under your car. Instead, take your car to a local gas station where the mechanic has one in his toolbox, let him put it up on the hoist and free it up. Simply nudge it tight for the ride home, pay $20 for the 15 min work,and you're good to go!
--Jeff
rugrat
Jun 8, 2013 10:08 PM
Staged206K
Jun 8, 2013 04:44 PM
draser
Mar 9, 2009 12:13 PM
lvs4rock
Oct 25, 2008 04:31 PM
accordfan222
Oct 14, 2007 07:19 AM
