Cruise Control
Old Dec 19, 2007 | 12:38 PM
RR_Rex's Avatar
Default Cruise Control
I have a 2002 Accord 4cyl auto SE Coupe whose cruise control no longer works. I had to recently replace my brake light switch. Can the two be related? If not, where should I start?
Thanks
Old Dec 19, 2007 | 01:12 PM
deserthonda's Avatar
Default RE: Cruise Control
chk the adjustment on the brake switch,, if the little plunger sticks out , it is the same as stepping lightly on the brakes, it won't let the cruise control engage,
You want to make sure that the plunger is all the way in when brake pedal is in the up position
Old Dec 20, 2007 | 02:27 PM
RR_Rex's Avatar
Ok, I'll check that now.
Old Dec 20, 2007 | 03:24 PM
falkore24's Avatar
LOL ..... it might be easier to see if your brake lights are on all of the time or if you can shift out of park without hitting the brakes ..... same effect.
Old Dec 20, 2007 | 06:49 PM
RR_Rex's Avatar
Brake lights are not constantly on. Is the Cruise Control tied into the brake light switch? Could I have gotten a falty switch/the wrong switch?
Old Dec 20, 2007 | 09:04 PM
HondatechAV6's Avatar
if the connector connected to the brake switch most likely it's the right switch. when you install it you need to bottom out the switch with the pad. you want that little plunger depressed with the brake pedal released and extended when you press the pedal, know what i mean? i'll post a few pics if you need them. let me know
Old Dec 22, 2007 | 06:28 PM
RR_Rex's Avatar
I'm fairly sure I know what you mean, but I'm a visual learner, so post away.
Old Dec 29, 2007 | 02:04 PM
Old Dec 29, 2007 | 02:27 PM
ckebottle's Avatar
call of duty 4 is so much fun! i like how you added that to your picture lol
deckerhonda
Jan 24, 2006 09:12 PM
wskipper
Nov 19, 2005 03:49 PM
SeminoleB
Nov 9, 2005 01:52 AM
rabbit
May 3, 2005 01:28 AM
austinbc1
May 2, 2005 08:16 PM
