Cruise Control 97 EX
Old Dec 23, 2008 | 11:27 PM
accordin2u's Avatar
Default Cruise Control 97 EX
Hey guys I replaced the 2.2 vtech in my 97 and now my cruise control doesn't work. When I was lowering the engine back in the car it did hit something on the firewall next to the cruise control section under the hood. The switch on the dash works and the light in the cluster comes on but the cruise does not engage. Any suggestions would be helpful and appreciated. Thanks.
Old Dec 24, 2008 | 09:11 AM
sir_nasty's Avatar
Default RE: Cruise Control 97 EX
most common things first, make sure that your throttle cable is properly adjusted, then check that your brake switch (top of the brake pedal) is set properly as well (fully disengaged with foot off the brake).
Any CEL on or ANYTHING else on the car operating in a strange matter?
Old Dec 24, 2008 | 11:51 AM
Check that vacuum supply from end of throttle bodyto cruise control is connected.
Old Dec 26, 2008 | 08:26 AM
accordin2u's Avatar
I will try these things today
Old Dec 26, 2008 | 09:50 PM
accordin2u's Avatar
Everything is connected ,there is no CEL, brakelight switch is correct. Something definetly happened when putting the engine back in the car. What could I have done?[sm=feedback.gif]
Old Jan 3, 2009 | 06:51 AM
It is possible to mis-rig the throttle actuator. I would apply vacuum directly to see if actuator is functioning.
Another possibility is the M/T clutch switch or A/T shift position console switch is not supplying a closed signal to the cruise control unit.
I would download the shop manual from Online Manuals DIY and go through the actuator tests.
deckerhonda
Jan 24, 2006 09:12 PM
wskipper
Nov 19, 2005 03:49 PM
SeminoleB
Nov 9, 2005 01:52 AM
rabbit
May 3, 2005 01:28 AM
austinbc1
May 2, 2005 08:16 PM
