Cruise Control Doesnt Work
Old 03-04-2011, 02:14 PM
Adler's Avatar
I finally got around to checking out the cruise control.
First of all, I couldnt get the module itself out of the car, Im not sure how its in there.
I got the cable off and found a bit of an issue, I'd like your opinions as to whether it is the cause of the cruise control not working at all.
Here are pics of the damage...
Old 03-04-2011, 06:25 PM
This is where cable enters the cruise control vacuum actuator. This actuator "pulls" the cable so I don't think this would disable the actuator. I had something similar and used some wire to hold the end stop in place.
Have you check vacuum supply and lines as suggested?
Old 03-05-2011, 07:44 PM
Adler's Avatar
I strongly doubt that the broken plastic was an issue, but I went ahead and fixed it anyways;
That is JBWeld you see on there.
I havent had time to check the vacuum hoses and actuator yet but that is next on the agenda.
Old 03-06-2011, 08:08 AM
I've made similar repairs on plastc items. I've found that embedding a layer of ripstop nylon fabric into the repair greatly strengthens the repair, providing more tensile strength to the epoxy.
Old 03-06-2011, 01:06 PM
Adler's Avatar
So I took the whole cruise control assembly out, the reason I couldn't get it out before was because I didn't realize that the whole thing came out, bracket and all, not just the thing that houses the diaphragm. I found the problem and it was a pretty sad one. The vacuum hose was detached... sheesh. So now my cruise control works AND I fixed a vacuum leak I didn't know I had.
The hose is pretty tight though, so I may still replace it with one that is an inch or two longer to prevent the same thing from happening again.
Old 03-07-2011, 06:12 PM
aloha_bruddah's Avatar
can you take a pic of where this is located??? I tried to follow but got lost.......where exactly is the CC module?
  #17
Old 03-07-2011, 09:19 PM
Adler's Avatar
On the 95 it is right next to the firewall on the passenger side. Right next to the fuse box. It has a cable that runs over the valve cover to the throttle in a big loop. It looks like a cylinder with a cable that goes into it
  #18
Old 03-08-2011, 11:54 AM
ok, i'll look.........don't know if the 93 is any differennt.........thanks...
  #19
Old 03-08-2011, 12:03 PM
I believe cruise control actuator on 93 Accord is near the power steering unit on drivers side. If you trace the cable/sleeve from throttle linkage, you have to find it.
Old 03-14-2011, 12:00 AM
Default hehe, i suck....help..
so here's a pic of my engine, where am I to be looking????
Quick Reply: Cruise Control Doesnt Work
