Cruise control intermittant 2003 4cyl
Old Jan 22, 2013 | 03:03 PM
jjk61083's Avatar
Default Cruise control intermittant 2003 4cyl
Have a 2003 Accord LX Sedan with the 4 cyl engine. Sometimes the cruise works perfectly but other times it will not work. When I press the main button, the light comes on, but when I press the set button the green cruise light will light up for a second and then go off. Press it again and it does the same thing. Sometimes after pressing it 15 or 20 times it will stay on. Any ideas? Thanks.
Old Jan 22, 2013 | 04:06 PM
Check for an intermittent problem with your brake lights? If the switch on the brake pedal is not adjusted properly it might cancel the cruise (and light up the brake lights) when you're not really on the brakes.
If you have a manual transmission, same thing for the switch on the clutch pedal.
Old Jan 22, 2013 | 04:19 PM
Dr. Drivability's Avatar
mine does the same exact thing, haven't had time to diagnose, but let me know if you figure it out...i'll do likewise.
Old Jan 23, 2013 | 01:31 PM
jjk61083's Avatar
Jim,
Is there a description somewhere that shows the proper adjustment for the brake switch?
Old Jan 23, 2013 | 04:56 PM
I would just check to see that when the pedal is up, it pushes in the plunger of the switch. Make sure that the brake lights are coming on only when the pedal actually moves a couple mm.
Old Jan 23, 2013 | 08:10 PM
jjk61083's Avatar
Ok I checked the pedal, it is pushing in the plunger on the switch when it's up and brake lights only come on when I push pedal in just a little. Cruise control did work fine tonight coming home from work.
Old Jan 26, 2013 | 08:09 AM
It can "look" closed but testing the pins on the switch would be the best.
Attached Thumbnails Cruise control intermittant 2003 4cyl-7th-gen-brake-switch-test.jpg
Old Feb 23, 2013 | 11:27 AM
jjk61083's Avatar
Just an update on cruise control. I've noticed that if I try to put cruise on and it does not work, I just put my foot under the brake pedal and pull up just a bit it and then hit the cruise button it works every time.
Old Feb 23, 2013 | 11:43 AM
time to adjust or replace the stop lamp switch.
Old Feb 23, 2013 | 11:51 AM
Brake light switch is either out of adjustment or sticking. You can loosen the lock nut and give it a 1/2 turn (or so) in towards the pedal and then tighten the lock nut.
Think of the brake switch as having three positions.
Brake lights on - brake lights off - cruise circuit closed
The fact that you can "lift up" on the brake pedal and then the cruise works tells me that something is not allowing the brake switch go from "brake lights off" to "cruise circuit closed".
EDIT: slow typing......guess that is what I get for typing and watching tv ......I see the Dr posted as I was typing.
