cv axle
Old Sep 27, 2019 | 03:08 PM
The Toecutter's Avatar
Originally Posted by shipo
After reading a lot of glowing reviews on various Acura web sites, I just swapped the 1-Year old Duralast axles (probably repackaged Cardone units) on my TL with a very inexpensive set of new APWI axles; I believe APWI makes axles for most Accords and they are typically between $45 and $50 per side. Not bad, under $100 for two new axles which operate nice and smooth with nary a shimmy.
Do you have a link for APWI?
Old Sep 27, 2019 | 03:18 PM
shipo's Avatar
I do not; just lots of buzz about them on the Acura sites; I found mine on RockAuto.com
Old Sep 27, 2019 | 03:30 PM
Ok, thanks.
Old Sep 27, 2019 | 06:41 PM
kmp123's Avatar
05 accord manual 6 speed 3.0, do these models have intermediate shaft ?
Old Sep 27, 2019 | 07:07 PM
Seanjordan20's Avatar
Yes it does but I doubt I doubt that's the issue. I bet if you put a Honda shaft on it would clear up.
Old Sep 27, 2019 | 09:33 PM
shipo's Avatar
The intermediate shaft is HIGHLY unlikely to be your issue.
If APWI axles weren't available for my car, I'd opt for these:
Old Sep 28, 2019 | 01:41 PM
  #17
When I was still a member of 6th gen Accords, one of the users there took his Accord to the dealer for replacement of the drive axles. They used NAPA axles on it. :O His parents were paying the bill, so the car always went to the dealer. D'oh.
Old Sep 28, 2019 | 11:23 PM
  #18
kmp123's Avatar
thanks, axle came in today, I think I should get a set ring for the intermediate shaft, just in case other one is rusted or corroded.
44319-S84-300 I think it is this one. will see if there is one at the dealership.
Old Oct 2, 2019 | 10:56 PM
  #19
kmp123's Avatar
can't get axle nut off, broke two breaker bars. wd 40, candle wax. does this mean axle is frozen to hub too, how do I get it off ?
going to grind off some of the nut with a 4 inch grinder, to weaken it. then hit it with a breaker bar/socket again.
Old Oct 3, 2019 | 07:09 AM
  #20
Is the car on the ground. If you're using a breaker bar and have a pipe to go over the bar for more length use that. I usually use my jack pipe as it's 5 ft long. It will break it easily. Once broken then lift off the ground
