CV???? engine mounts???
Old Nov 21, 2007 | 01:59 PM
00AccordLX5spd's Avatar
Registered User
Default RE: CV???? engine mounts???
ORIGINAL: klrspz
I've also had the same symptoms in a Saturn where the starter clutch was slipping out of place AFTER being started...
I thought Saturns were made of styrofoam
Old Nov 21, 2007 | 03:33 PM
drummer1279's Avatar
no thats a Kia, styrofoam and plastic engine/tranny compnents. lol sounds like to me either a tranny mount loose or the CV is coming loose on the tranny side.
Old Nov 30, 2007 | 12:32 PM
falkore24's Avatar
well .... both lower engine mounts are blown .... the rear is pretty bad. Oh yeah ..... the V6 has vacuum lines on both ..... yea, more for me to screw up on. I'm changing all 3 and packing them with poly if I can do it tonight. I'm also adding a torsion damper since the rear mount is only a year old.
Old Nov 30, 2007 | 03:45 PM
ckebottle's Avatar
Sounds like you'll have a lot of fun tonight with that. At least it's not your transmission
Old Nov 30, 2007 | 06:51 PM
Just out of curiosity, how would you blow out all of the mounts at the same time?
Do you think that the rear one went out, and basically tore up the other one?
Old Nov 30, 2007 | 08:16 PM
HondatechAV6's Avatar
the front mount usually goes bad and then the passenger side mount, then the lower driver side mounts and finally the rear. it's actually not too bad.
i do the front and side mount in 10 minutes. the rear...it's a pain in the bootahy.
Old Dec 3, 2007 | 11:08 AM
  #17
falkore24's Avatar
Well, my machinist friend and I replaced the lower mounts on Saturday and what a bitter cold day it was!!! The front mount was pretty worn. You can wobble it pretty easilly. The rear was blown apart! It had a huge tear in the rubber and was filled with stank old water that spilled on my friend and his Summit Racing pad. The rear wasn't really any harder than the front, actually there is more room around the rear one. We had one bolt that appeared to have been locked in place by aluminum shavings from the block .... a little tap, die and file work fixed that. The side mount is sagging, but that's not what was causing my wheels to skip, so it can wait for a warmer day ..... along with my torsion damper that is scheduled to arive tomorrow.
BTW --- packing the mounts with poly actually DOES work!!!! I can feel a little rumble at idle now. I expect it to get stronger when I change the last mount and add the damper, but that should be the end of the blown engine mounts on this car ..... hopefully.
Old Dec 3, 2007 | 12:52 PM
  #18
sir_nasty's Avatar
How on earth did you blow all those mounts?
Old Dec 3, 2007 | 01:28 PM
  #19
ckebottle's Avatar
ORIGINAL: sir_nasty
that's what happens when you drive a v6 6th gen with " w/ lots of toys "
Old Dec 3, 2007 | 03:56 PM
  #20
falkore24's Avatar
LOL .... I have the rear to take a pic to show you guys ..... the front and side are worn .... I think that they are original, but worn to the point of replacement. The rear is likely my fault from how I drive, but the others are lust 8 years old I guess.
See why I have a damper going in?
mpanelli
Nov 9, 2014 08:39 AM
19962door
Oct 23, 2008 11:52 AM
ozzie2000
Apr 29, 2008 11:51 PM
elucho02
Apr 1, 2008 08:54 AM
BuntinBoy9
Feb 17, 2008 02:51 PM
