Cylinder 2 Misfire
Old Jul 8, 2012 | 07:55 PM
jvog's Avatar
Default Cylinder 2 Misfire
I have a 1996 Honda Accord 2.2 Vtec. The car started misfiring the other day so I checked the cod and it was for a cylinder 2 misfire. I swapped out the plugs and wires, but the problem persisted. I then swapped out the cap and rotor, and it didn't help at all. It only misses under 3k RPMs. Above that, it seems fine. I though it was a spark related issue for sure, but now my only other guess would be a bad injector. But would a bad injector only cause issues under 3k RPMs? I did read that EGR issues sometimes cause a misc misfire code, and I have had an EGR code on for a while but havent gotten around to fixing it. I don't remember the code #, but it said something about exhaust gas recirculation. So, I'm stumped with this misfire thing. Anyone have any ideas (besides an injector)? Thanks
Old Jul 8, 2012 | 08:54 PM
The misfire may be due to the clogged EGR ports, clean that first and see if it resolves it.
In the DIY "sticky" above in this forum, is a link on how to clean the ports.
Old Jul 16, 2012 | 08:40 PM
jvog's Avatar
Thanks, I cleaned the EGR ports and that did the trick.
Unfortunately, now I've got fuel leaking from the fuel rail. It didnt leak during 2 days worth of driving, yet started doing it today.
I'll pop the fuel rail off and try re-seating it on the injectors.
Old Jul 17, 2012 | 08:15 AM
New O-rings for the injectors? Normally you can't re-use them because they get hardened from age & heat.
Resatimm
Apr 28, 2016 05:56 PM
Rena
Oct 25, 2012 09:56 PM
imjrk
Dec 2, 2008 09:05 PM
finch13
Dec 23, 2007 05:01 AM
caverspencer
Nov 16, 2007 01:58 AM
