Cylinder 3 misfire (cant get rid of it)
I am to the end of my knowledge on this issue.. Any help or advice would be greatly appreciated..
1997 honda accord completely stock. 4 cylinder 2.2
keep getting cylinder 3 misfire no matter what i do.. Car shakes violently when put in gear but runs out smooth when given gas or driven down the road. Only does this when idling, and when you pop the a/c on it gets worse..
Heres a list of the things ive already done.
Plugs, wires, distributor cap, rotor button, compression 150+ on all cylinders, adjusted timing for it was one tooth off but problem still persist.. Switched injectors on cylinder 3 and 4 but still misfiring on 3.. Have 12 volts to all injectors.. Ive done everything i can think of and didnt want to keep throwing parts at it.. Doesnt smoke or overheat.. I can pull the wire off 3 and the motor doesnt change tune as it does on all other cylinders.
Has anyone seen or heard of this or could point me in the right direction.. Thanks!!!
