D4 code and ABS code.
Old Jan 18, 2009 | 09:04 AM
madsteez's Avatar
Default D4 code and ABS code.
This morning I was doing some testing on my 94 accord lx. When I checked for stored codes I got:
3 fast D4 codes followed by:
2 fast ABS codes and then 1 fast ABS code.
Does anyone have any idea what this means?
Heres a video for reference. Dont mind the CEL I unplugged the Oxygen Sensor to test it with a multimeter.
http://s3.photobucket.com/albums/y60...t=MVI_1966.flv
Old Jan 18, 2009 | 09:18 AM
Default RE: D4 code and ABS code.
Code 3 flashed on D4 light is Lock-Up Clutch does not engage. Cause is electrical fault (short or open)in throttle position circuit or faulty throttle position sensor. Check wiring and connector carefully, and then perform TP sensor checks per shop manual.
ABS code was probabaly 2-1 which is two fast blinks, 1-sec pause, followed by 1 fast blink. Are you sure of code? I would suggest rechecking. There is no 2 stand-alone code, hence I thought it was 2-1, but you need to be sure. 2-1 is code for a parking brake fault. A large number of possibilities are listed in shop manual in the ABS section.
To get the extensive details to be checked, download the 94-97 Accord manual from one of the Online Manuals links in DIY section.
Old Jan 18, 2009 | 09:36 AM
madsteez's Avatar
It most likely threw the TPS code because I unplugged that as well to test it.
It is a 2-1 ABS code which makes no sense to have a code for the parking brake.
Old Jan 18, 2009 | 04:20 PM
It's described in detail in the ABS section of shop manual. There are a number of possibilities related to parking brake.
Old Jan 18, 2009 | 07:43 PM
If you were to use the handbrake to slide the rear wheels, the ABS is programmed to NOT interfere. However, it DOES complain by setting the ABS lamp.
93Accord2.2
Nov 7, 2013 07:10 AM
JJC
Mar 13, 2013 06:17 PM
yankee707
Jan 27, 2013 06:32 PM
Custnam
Oct 28, 2012 12:50 PM
HondaPhyco
Dec 27, 2007 09:39 PM
