D4 light is on. (1992 Honda accord)
Old Oct 28, 2013 | 05:41 PM
ngonzo523's Avatar
Default D4 light is on. (1992 Honda accord)
I have a 1992 honda accord and i just replaced the main relay due to problems with the car not starting on really hot days. Since ive changed the relay the D4 light stays lit and a clicking noise comes from the cockpit also its on limp mode. I was told to check the TCU which i did. there is no burnt out components on the circuit board. I cannot figure out this problem.. Can someone help me out???
Old Oct 30, 2013 | 05:42 PM
Check the codes (CEL and D4), what do you have?
For giggles. Clean the battery cables, I'd also clean the "other" end of the ground cable - it contacts the body and then the trans.
Last, there is a ground on the t-stat housing as well, I'd pull and clean that.
mike24112
Nov 14, 2012 06:11 PM
slammed accord
May 30, 2012 09:53 PM
rsmith777
Aug 4, 2011 01:32 PM
imabadczech
Oct 5, 2010 04:50 PM
