D4 light blinking
Old Oct 17, 2008 | 01:51 PM
ryan2681
Default D4 light blinking
Hi,
I have a 98 honda accord ex...I had a trans put in the car about a year ago...The guy told me when he put it in, they messed up and sent him a trans with posi traction...I had the car repainted and it sat for almost a year..When i picked it up and drove it home the trans did a mis shift and now the check engine light is on and the d4 light is blinking.I took it to a trans shop and the guy put new silonodes in it and it didnt fix it...he thinks its the tran control unit...he said the trans looks fine but to take it to the dealer to have it scanned by them..i called honda and they told me over the phone it is one of two things either the silonodes are bad or it mechanical failure...havent had a chance to have honda read it yet, but does anyone have any suggestion what might be wrong....The car has low miles 120k but i dont want to dump a new trans in (honda said $3,500) if the car is that old and i have to put more money in it then its worth...
Old Oct 17, 2008 | 01:57 PM
finch13's Avatar
Default RE: D4 light blinking
Could be TCU... can you pull the codes for us?
And sounds like your mechanic is stuck in a dumbestic era... Posi Trac lol.
Old Oct 17, 2008 | 02:08 PM
ryan2681
I believe the codes were p0700 and p1773....
Old Oct 17, 2008 | 02:12 PM
finch13's Avatar
P0700 Transmission Control System Malfunction
finch13's Avatar
[align=left]P1773 Automatic Transaxle Concerns [/align]
Old Oct 17, 2008 | 02:19 PM
ryan2681
sorry dont know alot about transmissions....So what do you think that means?
Old Oct 17, 2008 | 02:21 PM
finch13's Avatar
p0700 leads me to think the TCU is faulty (burnt resitors/transitors/capacitors) which you can replace the unit or fix it yourself...
p1773 makes me think solenoids... but the TCU issue may cause them to register a code since the TCU isn't operating correctly.
Old Oct 17, 2008 | 03:48 PM
ryan2681
Do you have to get the tcu flashed by honda if you buy a used one? Where do you think the best place to get one would be?
Old Oct 17, 2008 | 03:53 PM
finch13's Avatar
Doesn't need to be flashed. A used one can be had at a salvage/junk yard for about $60 - 100 and they should have tested it so it works.
Old Oct 17, 2008 | 05:07 PM
ryan2681
Thanks for the advise...I'll give it a try this weekend and let you know...
