D4 light blinking
Old Oct 17, 2008 | 05:41 PM
Default RE: D4 light blinking
I think P0700 is general transmission fault. It is always there when a trans code is set. If you get the OBD1 code you'll get a 70 which is shown with all the OBD2 trans codes. If your TCU is reporting a code, it's probably OK, IMO.
See definition of P1773 for Honda. It may be an electrical faulty in solenoid B. http://www.aboutautomobile.com/dtc/P1773
Old Oct 17, 2008 | 08:44 PM
f allen's Avatar
if it were me id go to the junk yard and get a tcu , all you do is locate it and plug it in, i just put one in my accord and it made all the difference
Frank Allen
Old Oct 17, 2008 | 11:13 PM
ford's Avatar
yep its most probably the TCU from what im reading...and the code that you said..just like what finch13 said...and yeah finch i agree wo what u said bout that mechanic...LOL...posi trac...
Old Oct 18, 2008 | 10:48 AM
f allen's Avatar
Just remebered one more thing, had this problem with a car i worked on, it turned out to be the main fuel relay under the left side of the dash board, i found out that a voltage goes from that realy to the tcu , they are inecpensive from honda, the honda parts place told me they sell about 8 a month, this thing can make your car do some weird things. on the car we worked on we had to replace the pigtail that is attached to the relay because of poor solder joints, after that no more trouble, worth some thought anyway, this will sometimes cause start up problems as well but not always
Frank Allen
Old Oct 18, 2008 | 04:26 PM
ryan2681
I've been calling around looking for this unit with no success...Honda tells me that the tcu is an all in one unit with the ecm...They also told me if i got a used unit it would need to be flashed from them because its a single unit called a pcm...Anyone know if this is true?
Old Oct 18, 2008 | 04:52 PM
Try car-part.com for a used unit near you.
Old Oct 20, 2008 | 01:07 PM
  #17
I used to have a 98 and YES the engine & tranny controllers are together in a unit that Honda calls a PCU (powertrain control unit). I dont know why it would need to be flashed...
I guess it would be a different unit fornon-VTEC vs VTEC vs ULEV-VTEC engine. Plusyou would have to be careful about compatibility if you try to use one from a 1999-2002 car.
Old Oct 20, 2008 | 01:28 PM
  #18
finch13's Avatar
Jim,
is the PCU a complete, all-in-one-box unit? If so, sorry to the OP for confusing you, 1997 and older have and ECU and TCU that are completely separate units with their own wiring harnesses.
Old Oct 20, 2008 | 01:32 PM
  #19
All-in-one box.
land shark
May 28, 2021 08:20 PM
horsebird
Dec 18, 2011 10:44 AM
shoispo
Feb 6, 2007 05:07 PM
wallc777
Oct 23, 2006 09:28 PM
shadowcrzr
Mar 17, 2005 03:17 AM
