D4 light Blinking
Old Sep 28, 2009 | 06:32 PM
bubbasidewinder
Default D4 light Blinking
I have a 93' Honda Accord EX I recently replaced the heater hose ( one under distributor). Afterwards I found my D4 light blinking and my check engine light came on. It is also harder to start when the engine is cold and it smells to be running richer. Also I feel like my gas mileage has dropped although I dont know for sure. Any Ideas?
Old Sep 29, 2009 | 07:21 AM
Look for stuff that you may have unplugged while you were working on the hose?
Coolant temperature sensor on the head under the distributor?
Dirty/corroded connections at tranny's shift-control solenoids?
Loose grounds at the thermostat housing?
VSS? (but that shouldn't afffect starting & fuel mixture)
Old Sep 29, 2009 | 10:43 AM
deserthonda's Avatar
chk the wiring, connector to the TW SENSOR
Old Sep 29, 2009 | 07:56 PM
hondadude's Avatar
Jumper the BLUE 2 pin Connector behind the passengerside kick panel, turn on the key and count the 'D4' flashes.
land shark
May 28, 2021 08:20 PM
horsebird
Dec 18, 2011 10:44 AM
shoispo
Feb 6, 2007 05:07 PM
wallc777
Oct 23, 2006 09:28 PM
shadowcrzr
Mar 17, 2005 03:17 AM
