d4 light is blinking
My d4 light always blinks. The transmission shifts fine. When the car is warm and I'm in park of neatral the idle goes up and down from 1000rpm to 1500rpm. the check engine light is on. Any suggestions on what is going on would be greatly appreciated.
Suggest you start by getting the codes, see the Common DIY Threads sticky at the top of this section for a "how to". Be sure to get all codes (D4 and CEL), post what you find and please note which code came from where.
The idle, sounds like low coolant, air in coolant or a dirty IAC but lets start with the codes.
that what my car was just doing too. Its a pretty easy fix. First check the plug to make sure its got good connections. If that parts good then youll just need to replace it. I couldnt find a way to get it off without taking the distributor off, but it wasn't too hard/
I replaced the sensor and the check engine light went away as well as the D4. thankyou for your help. the idle problem is not as bad, but could still use work I've read that bleeding the coolant system sometimes fixes it, I'll try that.
horsebird
Dec 18, 2011 10:44 AM
