d4 light is blinking
Old Mar 17, 2012 | 01:01 PM
jonesy17's Avatar
Default d4 light is blinking
My d4 light always blinks. The transmission shifts fine. When the car is warm and I'm in park of neatral the idle goes up and down from 1000rpm to 1500rpm. the check engine light is on. Any suggestions on what is going on would be greatly appreciated.
Old Mar 17, 2012 | 01:24 PM
What year accord are we talking about here?
Old Mar 17, 2012 | 01:41 PM
jonesy17's Avatar
It's a 94 ex
Old Mar 18, 2012 | 07:35 AM
Suggest you start by getting the codes, see the Common DIY Threads sticky at the top of this section for a "how to". Be sure to get all codes (D4 and CEL), post what you find and please note which code came from where.
The idle, sounds like low coolant, air in coolant or a dirty IAC but lets start with the codes.
Old Mar 19, 2012 | 11:36 AM
jonesy17's Avatar
the CEL gave me #6, and the D4 didn't give any codes when I shorted it
Old Mar 19, 2012 | 09:18 PM
Suggest adding your car info to your signature so you don't forget to add it.
OBD-I code six from the cel is for the ECT, two wire sensor directly under the dist......
Old Mar 20, 2012 | 07:02 PM
fritosaregood's Avatar
that what my car was just doing too. Its a pretty easy fix. First check the plug to make sure its got good connections. If that parts good then youll just need to replace it. I couldnt find a way to get it off without taking the distributor off, but it wasn't too hard/
Old Mar 20, 2012 | 07:19 PM
jonesy17's Avatar
I replaced the sensor and the check engine light went away as well as the D4. thankyou for your help. the idle problem is not as bad, but could still use work I've read that bleeding the coolant system sometimes fixes it, I'll try that.
Old Mar 21, 2012 | 09:00 AM
Be sure the coolant is full, then try the bleeding. If that doesn't help, read about cleaning the IACV
land shark
May 28, 2021 08:20 PM
horsebird
Dec 18, 2011 10:44 AM
shoispo
Feb 6, 2007 05:07 PM
wallc777
Oct 23, 2006 09:28 PM
shadowcrzr
Mar 17, 2005 03:17 AM
