D4 light flashing code 18 (not on list) AND...
Old Nov 3, 2016 | 12:04 PM
PapillonOne's Avatar
Default ABS light flashing code ?
Hello everyone.
Hoping to get some advice regarding my 94 Honda Accord EX Station Wagon's newest issue. Went to drive it yesterday evening, got a block from home and the D4 light started flashing so took it right back home.
Found the info on code 18 in another post (actually is a code 1 or 10 and a code 8) BUT... while the CEL did not flash, the ABS light did, which I've never seen happen before. It first flashed 3 short, then 4 short, then 8 short and then did not flash again. I am not sure if that stands for 348 or 48 or something else but I would really appreciate if anyone can tell me what that means. I did find a reference to the ABS flashing in the DYI section but still not sure if I am reading the flashing right as it flashed 3 sequences and not 4.
thanks for any clarifications.
Thanks for any help you can give me!
Last edited by PapillonOne; Nov 3, 2016 at 12:55 PM. Reason: Found info on D4 light
Old Nov 3, 2016 | 05:39 PM
I'd recheck the code(s). The ABS light turns on for 2 seconds, off for two seconds, then starts flashing codes.
The main code will flash, pause for 1 second, then the sub-code will flash. There is a 5 second pause for the next code to flash.
i4ex
Dec 3, 2014 11:01 PM
hitechredneck
Aug 15, 2013 08:14 PM
jwk8199
Sep 23, 2010 03:47 PM
Stener75
Jul 25, 2010 08:21 PM
MikeT
Mar 11, 2008 10:25 AM
